it keeps overheating
161,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
MELISSA MONG
we have changed and cleaned everything. there is no evidence of a head gasket leak, but it keeps overheating.
Sep 30, 2019 at 4:42 AM
SCGRANTURISMO
  • 4,897 POSTS
What have you cleaned and replaced so far?
Thanks,
Alex
2CarPros
Sep 30, 2019 at 7:50 AM
MELISSA MONG
we have clean all the hoses and the radiator. replaced water pump and thermostat. replaced thermostat housing.
Sep 30, 2019 at 9:32 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, can you please check the serpentine belt and make sure it has proper tension and is not misaligned. If there is a problem with the serpentine belt it would slip and not spin the water pump at the correct speed causing your vehicle to overheat. Please get back to us with what you find out.
Thanks,
Alex
2CarPros
Sep 30, 2019 at 8:30 PM
