it is possible gasoline goes too engine oil
3.4L • V6 • 2WD • AUTOMATIC
LEZHAR2
  • 5 POSTS
Hello I am wondering is it possible that the gas/ gasoline can leak in engine oil ?
May 19, 2014 at 2:36 AM
HMAC300
  • 48,601 POSTS
it gets that way fro either a leaky fuel injector and/or repeated cold starts and engine not being frun for 10 miles or less. If this is what this vehicle has done to it change oil every 3000 miles along with filter.
May 19, 2014 at 2:45 AM
LEZHAR2
  • 5 POSTS
but if I change the oil filter and oil is not dangerous that cas leak too the oil again?
May 19, 2014 at 4:26 AM
LEZHAR2
  • 5 POSTS
and what can I do to make it repaired?
May 19, 2014 at 4:28 AM
HMAC300
  • 48,601 POSTS
first if you aredriving under 10 miles one way each time then start driving about 50 miles once a week if you aren't driving under those conditions then have a pro look at it to see if he can find the problem.
May 19, 2014 at 5:31 AM
LEZHAR2
  • 5 POSTS
im driving 3 miles one why, but it is harmful to the engine? or not? please help me?
May 19, 2014 at 9:17 AM
HMAC300
  • 48,601 POSTS
reread my very first reply very carefully and do what it says.
May 19, 2014 at 9:32 AM
LEZHAR2
  • 5 POSTS
Hi SIR again today I changed the engine oil, then found out that when it was not gas/gasoline, which was in the engine oil, but water, but the car does not get hot when I'm driving! what could it be? is the head gasket that ere to be destroyed or is it something else?thank you for your help
May 20, 2014 at 9:39 PM
HMAC300
  • 48,601 POSTS
have a pro pressure check for ahead gasket leak.
May 20, 2014 at 11:10 PM
