it doesn't want 2 pickup when u start the engine.
THEMBALEON
I have BMW 325i dolphin, it doesn't spark on 2,3,4 and 5. Only 1 and 6, and it alsobackfires at the exhost, I don't knw what could be the problem but I think its the sensor, could I be right?, I the injectors are workng well and also changed the petrol pump and filter.
Aug 6, 2013 at 10:05 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
if this car has coil on plug then each plug is commanded on by the ecm or a injector control module. the ecm will have to see crank and cam sensors to know what cylinder to fire. also if you can switch known good coils 1 or 6 with dead ones. if the dead cylinders come to life and vice versa then you have a bad coil. if not you'll need to check those sensors. if you cant read a data stream on a diag computer then simply unplug them and check the wires. look for breaks or rubs in all these wires and make sure theyre all plugged in completely,coils too
Jan 25, 2014 at 9:31 AM
