It cranks over but will not start
225,352 MILES • 5.2L • V8 • 2WD • AUTOMATIC
MIGUELACEVEDO
I replaced fuel pump a couple of years ago and has been parked, it started up and ran fine. now does not start. after checking the power connector for the fuel pump with a test light it is real dim.
Oct 8, 2017 at 6:33 PM
STEVE W.
  • 15,413 POSTS
Sounds like either corrosion at the pump connector or the pump itself. They do not like setting.
Do an amp draw test on the pump. 2-3 amps the pump is not actually pumping fuel. 5-9 amps the pump should be pumping. Any higher and the pump is probably bad from setting.
Oct 9, 2017 at 4:01 AM
