I tried to change the timing belt and couldn’t get the big center bolt off the crank shaft. I took all the little bolts off around it to remove the pulley. When I put any torque on it the motor just turned so I put the truck in gear then all I did was move the truck. Is their some kind of tool that will lock the motor or something?
Feb 22, 2010 at 4:32 PM
