1995 Isuzu Truck changing timing belt
1995 ISUZU TRUCK
132,000 MILES • 4 CYL • 2WD • MANUAL
MASON MONK
I tried to change the timing belt and couldn’t get the big center bolt off the crank shaft. I took all the little bolts off around it to remove the pulley. When I put any torque on it the motor just turned so I put the truck in gear then all I did was move the truck. Is their some kind of tool that will lock the motor or something?
Feb 22, 2010 at 4:32 PM
You can use an impact or a long breaker bar lock it in place underneath observe rotation and use the starter to loosen it
Feb 22, 2010 at 5:10 PM
