1994 Isuzu Truck idle
LEE DAUGHERTY
Engine Performance problem
1994 Isuzu Truck 4 cyl Four Wheel Drive 140000 miles
idles fine the will jump around from1000-2000rpm at same time temp gauge is jumping toward hot, but engine is not hot. 4cyl 2.6
Feb 7, 2009 at 12:24 AM
  • 110,248 POSTS
Hi:
It sounds like the throttle position sensor (TPS) is bad. Has the check engine light come on? Have you ever had the computer scanned.
Feb 26, 2009 at 11:14 AM
