1994 Isuzu Truck ecm
1994 ISUZU TRUCK
235,000 MILES • 6 CYL • 4WD • MANUAL
RPEAKE1110
is there any possible way to bypass my ecm on my 94 isu pickup i need to get it started and moved
Jul 24, 2010 at 6:29 AM
You cannot bypass the computer its the heart of the engine management system-if its cranking over and will not start-do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jul 24, 2010 at 10:02 AM
