1994 Isuzu Truck Changed starter but it still just clicks
1994 ISUZU TRUCK
209,000 MILES • 4 CYL • 2WD • AUTOMATIC
DIAZHAU1
My truck wouldn't start, it only clicks. Checked battery and it puts out 12.36 volts. Changed starter and it still just clicks. What could be wrong?
Nov 25, 2008 at 12:46 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:2a3dabc71c="Diazhau1"]Electrical problem
1994 Isuzu Truck 4 cyl Two Wheel Drive Automatic 209000 miles
My truck wouldn't start, it only clicks. Checked battery and it puts out 12.36 volts. Changed starter and it still just clicks. What could be wrong?[/quote:2a3dabc71c]
Ok, you checked the battery. you say it has 12.36v good, now what are the cold cranking amps. I ask because your battery can show fully charged, and as it stands it is, but if the CCA are low you will get the problem you are having.
So, try jump starting it. If it starts take it by your local auto parts store and have them check the battery.
Also, check all connections to the battery to the starter and the ground cable.
post finding here in forum.....
Nov 25, 2008 at 2:13 PM
JDALRYMPLE
Try cleaning your battery post and also the connections use baking soda and water mix then rinse with clean water
Jan 19, 2009 at 4:53 AM
