1994 Isuzu Truck Blower Motor
1994 ISUZU TRUCK
106,000 MILES • 4 CYL • 2WD • MANUAL
ABIDK
I get 12 Volts at blower motor connector but motor don't run. If I touch the fan blades and spin a little it starts to run.
Should I replace it or is there way to fix it.
Please advsie
Aug 1, 2010 at 12:37 AM
EDWARD.S
  • 166 POSTS
Hi,Also See If you Have A Ground At that connector To the blower motor ,If so You need To Replace The blower motor. They Are Not Repairable.
Hope This Helps You,
Good Luck
Edward S.
Aug 1, 2010 at 1:16 AM
