1994 Isuzu Truck
1994 ISUZU TRUCK
NICKH544
Electrical problem
1994 Isuzu Truck 4 cyl Two Wheel Drive Automatic
new alternator dummy lights come on but ac does not work where could the problem be now please respone as soon as possible
Sep 29, 2010 at 10:25 AM
BLUELIGHTNIN6
  • 16,542 POSTS
which light is coming on in dash? check engine light? is vehicle starting?
Sep 29, 2010 at 10:29 AM
NICKH544
yes vehicle is starting and runs these are the lights that work: batt. water. gas. OC2.
Sep 29, 2010 at 10:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
sorry but i'm still unclear about the concern you have. are you trying to repair the a/c or the gauge cluster or what..?
Sep 29, 2010 at 10:35 AM
NICKH544
my gauge lights stay on but the ac and blower fan will not come on where do i search from here?
Sep 29, 2010 at 10:39 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the gauge lights have nothing to do with the A/C so i believe you may have 2 separate issues. if the blower motor is not running at all then you will need to start by checking the fuses and the blower motor relay. check fusible links near starter or power distribution box
if you have external regulator check regulator.
go through all fuses really careful
Sep 29, 2010 at 10:41 AM
NICKH544
thanks for your help we will going to check and see if that works once again thanks for all your help talk to you later
Sep 29, 2010 at 10:48 AM
