Electrical problem
1993 Isuzu Truck 4 cyl Two Wheel Drive Manual
i CAN NOT FIND THE REGULATOR. MY FUSES AND BULBS ARE GOOD. AFTER A FEW MINUTES I LOSE MY TURN SIGNALS
Saturday, January 3rd, 2009 AT 12:08 PM
PHCOFFEEDRINKER
MEMBER
I do not know if your truck is the same but my turn signals go out sometimes as well. I found it has something to do with the hazard switch which is on the top of the steering column. If I move the hazard switch around and kind of move the wires a little bit while moving the switch around it makes the turn signals work again. Not sure why but it works for mine.
