1993 Isuzu Truck Misses over 55mph
1993 ISUZU TRUCK
12,500 MILES • 4 CYL • 2WD • MANUAL
JAZZMANXX
I have a 1993 Isuzu PU 2.3 4cyl engine with approximately 125,000 miles. Over 55 mph the engine hesitate or misses. How can I repair this? Thanks
Aug 26, 2010 at 3:14 AM
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 26, 2010 at 12:28 PM
