1.Disconnect the negative battery cable.
2.Raise and safely support the vehicle on jackstands.
3.If equipped, it may be necessary to disconnect and remove the EGR pipe to access all the starter bolts.
4.Tag and disconnect the starter battery and control wiring at the starter.
5.If equipped, remove the starter bracket and/or heat shield.
6.Remove the starter-to-engine bolts.
7.Move the starter away from the engine and down to remove from the vehicle. Some starter may be installed with shims between the starter and engine. When the starter is removed, these shims may fall out. Do not loose them.
To install:
8.Install the starter and shims, if equipped to the engine. Align the mounting bolt holes and insert the bolts. Hand-tighten the bolts.
9.Tighten the starter mounting bolts to 30-34 ft. lbs. (39-44 Nm).
10.Install the starter bracket and/or heat shield, if equipped.
11.Connect the battery and starter control electrical wires to the starter.
12.If the EGR pipe was removed, install it.
13.Lower the vehicle.
14.Connect the negative battery cable.
15.Start the vehicle to make sure the starter functions correctly.
Aug 31, 2010 at 11:29 AM
