1992 Isuzu Truck my truck over heats
1992 ISUZU TRUCK
21,785 MILES • 4 CYL • 2WD • MANUAL
MUCWALDO
My truck is overheating but it doesn’t seem to leak any water. Changed the thermostat. No water seems to be leaking from radiator or water pump please help me. Thanks
May 26, 2009 at 1:08 PM
Could be the radiator clogged-up or the water pump is defective if not get it block and pressure tested to find out more.
May 26, 2009 at 1:47 PM
MUCWALDO
I have 2 questions now, how do i fix the clogged radiator and is it to late to save the head because it has started to throw some smoke.Just barley throwing smoke, but shut engine off right away.Oil seems to still be clean which i think means thehead might still be savable. Thank you for your help guys.
May 26, 2009 at 2:06 PM
Try flushing out the radiator
May 26, 2009 at 2:40 PM
