1991 Isuzu Truck engine
JEMARMION
Engine Performance problem
1991 Isuzu Truck 4 cyl Two Wheel Drive Manual
what's the difference between re-building and to overhaul an engine
Feb 10, 2010 at 5:23 PM
  • 31,937 POSTS
Hi there,
Re built can mean just a re ring and new bearings, as an Overhaul would normally mead new piston rings, pistons, big end and main bearings, cam & bearings oil pump overhauled cylinder head crank re grind and a re bore , basically a new condition engine, but people do confuse the two terms, so i would be asking exactly what you are getting for your money,
Mark (mhpautos)
Feb 10, 2010 at 7:50 PM
