1991 Isuzu Truck clutch master cylinder
INTIASKIMAN
Transmission problem
1991 Isuzu Truck 4 cyl Two Wheel Drive Manual
how do you remove upper bolt on clutch master cylinder? Is a special tool needed, their doesnt seem to be enough room to get any of my standard tools on it.
Feb 27, 2009 at 10:29 AM
DAVE H
  • 13,383 POSTS
MASTER CYLINDER
Removal
Disconnect fluid level electrical connector wires (if equipped). Disconnect hydraulic lines at master cylinder, and plug ends to keep dirt out. Remove master cylinder and gasket from power unit.
Installation
To install, reverse removal procedure. Bench bleed master cylinder. Adjust pedal height and free play (if necessary). See PEDAL HEIGHT & FREE PLAY under ADJUSTMENTS
Apr 20, 2009 at 10:33 PM
