1989 Isuzu Truck wiring
1989 ISUZU TRUCK
JDALRYMPLE
Electrical problem
1989 Isuzu Truck 4 cyl Four Wheel Drive Manual
has anyone else had this problem and fixed it???
code 62 broken wire for mass airflow, where could the break be i've rewired and resolderd the connector to the mass but still no luck. also i have traced the wiring all the way back to the computer and still nothing. any advice????
Jan 18, 2009 at 10:35 PM
JNOVACK
  • 723 POSTS
here's how to test mass air flow semsor TESTING See Figure 1
https://images.2carpros.com/forum/automotive_pictures/52960_0900c1528006250b_1.jpg
Fig. 1: Blow through the sampling tube (A) when testing the MAF sensor Uncover the rubber boot on the sensor side of the harness connector. Remove the intake duct from the sensor. With a high impedance voltmeter, check for voltage between the white wire and ground while blowing through the sampling tube in the sensor. Voltage should be between 0.5-1.5 volts. If not, replace the sensor. Turn the ignition OFF. Install the intake dust and recover the connector with the rubber boot.
Jan 19, 2009 at 10:04 AM
SLRYAN666
do you think that you could tell me how to test the maf sensor for a 1999 ford f250 lariat? also, is there any way to test the coolant temp sensor? if so please explain.
Jan 1, 2010 at 1:33 AM
JNOVACK
  • 723 POSTS
testing your ford works on the same manor voltages may differ
Jan 11, 2010 at 3:53 AM
