1988 Isuzu Truck Ign Coil
LARRY DANLEY
Engine Mechanical problem
1988 Isuzu Truck 4 cyl Two Wheel Drive Manual
I need to test the Ign coil and would like to use Multimeter.
What setting do I set at on Multimeter.
What reading will I get if Coil is Good .
What reading will I get if coil is bad .
Oct 21, 2010 at 9:21 AM
  • 75,988 POSTS
See below not within range replace it-
Ignition Coil
Primary resistance 0.81 - 0.99 ohms
Secondary resistance 7.5 - 11.3K ohms
Oct 21, 2010 at 1:02 PM
