1987 Isuzu Truck no fire from coil
BUBBA_HOTEP43
Electrical problem
1987 Isuzu Truck 4 cyl Two Wheel Drive Manual unknow miles
no fire from coil,,,was wondering if converting from oem to accel cannsiter type performance coil is possible,,,and how do i do this? i am not a mechanic,,obviously,lmao
Jul 10, 2009 at 6:09 AM
MKENT3006
  • 9 POSTS
isuzu coils are very well built, i got into the same problem, it was not fireing, check the coolant thermal sensor, it is on the intake manifold, if you are at the passenger side fender facing the engine, it will be on the lower,right side of the intake manifold. there should be a small wire connected to it. if that wire is not plugged up, the coil gets no fire and the truck will not run.
Dec 20, 2009 at 2:40 PM
