1976 Isuzu 6BB1 motor Truck Oil into water
1976 ISUZU TRUCK
225,800 MILES • 6 CYL • 2WD • MANUAL
ALLSHAPIRO
Having a problem with oil pumping into the water system. Removed cyl head and replaced gasket. Removed oil cooler and replaced cooler and cover. The oil pumps out of the sump into the radiator in 5 minutes while on idle. The alternator was repaired prior to this problem if there is a connection. Could there be a core plug in the block near a water jacket that could be faulty.
Oct 20, 2009 at 7:58 PM
IEDWIN2000
Did you get the head checked ie crack tested?
Does your engine have an air compressor, some air compressors are water cooled, oil lubricated?
Dec 11, 2009 at 4:52 PM
