Having a problem with oil pumping into the water system. Removed cyl head and replaced gasket. Removed oil cooler and replaced cooler and cover. The oil pumps out of the sump into the radiator in 5 minutes while on idle. The alternator was repaired prior to this problem if there is a connection. Could there be a core plug in the block near a water jacket that could be faulty.
Oct 20, 2009 at 7:58 PM
