2001 Isuzu Trooper transmission leak
84,000 MILES • 6 CYL • 4WD • AUTOMATIC
BROOKSIDE
I have transmission leak in two areas. Is this a recall Isuzu issue. My mechanic at Firestone said his buddy had a Rodeo that had a transmission recall.
Jan 5, 2008 at 8:30 AM
  • 31,937 POSTS
Hi there,
I have no information on transmission re calls for your vehicle, but contact your dealer to make sure there is not an outstanding notice that may affect your car.
Mark (mhpautos)
Jan 5, 2008 at 9:00 AM
SAMVISHERE
NHTSA Campaign ID Number: 00V376000 - Hide Details 2001 ISUZU TROOPER ENGINE AND ENGINE COOLING:ENGINE:GASOLINERecall Date: 11/14/2000 Summary: VEHICLE DESCRIPTION: SPORT UTILITY VEHICLES EQUIPPED WITH 4-WHEEL DRIVE AND AUTOMATIC TRANSMISSIONS BUILT WITH TOD (TORQUE-ON-DEMAND). IN CERTAIN HIGH SPEED, FRONTAL CRASHES, MOVEMENT OF ENGINE COMPARTMENT COMPONENTS CAN CAUSE THE POTENTIAL FOR FUEL LEAKAGE. Consequence: FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE. Remedy: DEALERS WILL INSTALL A NEW, REINFORCED FUEL HOSE ASSEMBLY. NOTE: THE FUEL LEAKAGE ISSUE IN THIS RECALL CAMPAIGN IS NOT THE SAME AS THE ONE ADDRESSED IN THEIR PREVIOUS CAMPAIGN 00V-253. Potential Units Affected: 18462 Notes: ISUZU TROOPER
Jan 26, 2008 at 1:41 AM
