2001 Isuzu Trooper Transmissing jerking while driving
125,000 MILES • 6 CYL • AWD • AUTOMATIC
RABBIT06
I need some advice on the type of transmission repair needed to correct the jerking and what is a electronic mode switch error. Code is P0705.
Mar 30, 2010 at 4:13 PM
THIS IS MIKE
  • 686 POSTS
P0705 is a code for Transmission Range Switch(Mode Switch) Illegal Position
It may just be a blown fuse or you will need to replace the range switch.
Apr 6, 2010 at 5:26 AM
RABBIT06
Does the switch have anything to do with the a function of the transmission causing it to jerk and slip?
Apr 12, 2010 at 11:44 AM
  • 75,988 POSTS
When the last time you had the tranny serviced? don't recall get it done and see what happens or bring it in to a transmission specialist and get pressure tested
The transmission range switch inputs signal to the computer and from there the computer selects the upshifts/downshifts by activating a given shifting solenoid to provide the proper gear shifts-could be a sticking solenoid
Apr 12, 2010 at 9:35 PM
