2001 Isuzu Trooper Shifting problems or Range Sensor proble
2001 ISUZU TROOPER
143,000 MILES • 6 CYL • 4WD • AUTOMATIC
01TROOPER
My trooper is having a shifting issue in first gear. From a dead stop it slips out of first into what what seems to be neutral and then back into first before shifting to second gear. I'm not sure if this is the Range sensor causing this or something more serious. The transmission isn't old at all it only has 15000 miles on it and service was done very recently. any ideas would be greatly appreciated.
Aug 12, 2009 at 2:17 AM
PACWOLF745
[quote:92f5e58a12="01trooper"]Transmission problem
2001 Isuzu Trooper 6 cyl Four Wheel Drive Automatic 143000 miles
My trooper is having a shifting issue in first gear. From a dead stop it slips out of first into what what seems to be neutral and then back into first before shifting to second gear. I'm not sure if this is the Range sensor causing this or something more serious. The transmission isn't old at all it only has 15000 miles on it and service was done very recently. any ideas would be greatly appreciated.[/quote:92f5e58a12]
You may want to check shift linkage. It is a possibility that that is the problem.
Aug 12, 2009 at 3:31 AM
01TROOPER
How so? There's not much to adjust under there as far as shift linkage.
Aug 12, 2009 at 12:51 PM
