2001 Isuzu Trooper RPM surge between first and second gears
DARTHTANNER
Transmission problem
2001 Isuzu Trooper Four Wheel Drive Automatic 112700 miles
When accelerating from first to second the vehicle will rev up all of a sudden, then drop into second and the vehicle will jump. This only happens when the vehicle is cold, and between first and second. If I slowly accelerate into second, I can then push it without any issues.
Apr 15, 2010 at 3:43 AM
MERLIN2021
  • 17,250 POSTS
Has the fluid and filter been changed on it? Fluid level and color look OK? Some vehicles should have a band adjustment with the fluid and filter service, may not be a major issue, YET!
Apr 16, 2010 at 2:21 AM
DARTHTANNER
I bought this vehicle about 2 years ago, and have not had them flush the transmission. I was thinking about having someone do that soon, but I still need to know if you think it is worth keeping, or would I be better off selling it.
Apr 18, 2010 at 5:46 PM
MERLIN2021
  • 17,250 POSTS
I'm afraid you should know that better than me! Depends on how the engine ism burn any oil? Loose any antifreeze? If all that is OK, then, a tranny flush at about 125.00 is a good investment...
Apr 21, 2010 at 5:38 AM
