2000 Isuzu Trooper TRANSMISSION SLIPS AFTER DRIVING FOR A W
2000 ISUZU TROOPER
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
PALIGAWESA
MY TROOPER SHIFTS VERY WELL, BUT AFTER DRIVING LIKE 50-60 MILES IT STARTS SLIPPING BADLY. iT CAN'T GO IN REVERSE!!! BUT IF IT SITS FOR A WHILE!! THEN IT STARTS TO DRIVE FINE AGAIN. BUT IT MUST FOR A VERY GOOD TIME LIKE OVER NITE!!!
Dec 27, 2008 at 9:29 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
This is sounding like an internal problem with the transmission, if the transmission is starting to slip after a reasonable drive, it would suggest that it is an overheating problem possible caused by a faulty servo or a defective clutch pack, i would suggest that you get a transmission specialist to do a test & report for you, don't delay as each time it starts to slip you are doing more damage to the driving clutch packs.
mark (mhpautos)
Dec 27, 2008 at 11:54 AM
