2000 Isuzu Trooper transmission slipping
2000 ISUZU TROOPER
10,500 MILES • 6 CYL • FWD • AUTOMATIC
BJALLEN623
My transmission started is slipping. Three weeks ago i had my EGR ports cleaned. Four days after the work was done my transmission started shaking upon going into 2nd gear. Yesterday the transmission completely became sluggish and hesitated to pull while automatically going into 2nd gear. Could the EGR cleaning have affected the transmission? There were no know problems to transmission prior to the egr work
Dec 31, 2007 at 12:33 AM
WATSON45
I also have a 2000 trooper and I am having the same problem as you. Changed my EGR valve and then started having problems with my transmission. Have you had any luck in fixing the problem?
Feb 23, 2008 at 9:22 AM
SQUARELOGO
I also have a '00 Trooper that has a slipping transmission. It started one morning in -15 degree weather and I thought it was just the cold, but it's been happening ever since.
I haven't messed with the EGR, but I can't really understand how that would affect it.
Feb 27, 2008 at 7:29 AM
