HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Isuzu
Trooper
Engine
Camshaft
Lifter
2000 Isuzu Trooper stuck lifter
MICHAEL8477
MEMBER
2000 ISUZU TROOPER
Engine Mechanical problem
2000 Isuzu Trooper 6 cyl Automatic
how can I git the lifter unstuck without takin it out any hints?
Sunday, May 30th, 2010 AT 12:35 PM
KHLOW2008
MECHANIC
Hi michael8477,
Is your vehicle equipped with hydraulic or adjustable lifters?
From our database, the engine should be with adjustable valve lifters and if that is the case, valve clearance adjustment is necessary.
Sunday, May 30th, 2010 AT 3:33 PM
Please
login
or
register
to post a reply.
Related Camshaft Lifter Content
Camshaft Timing
I Would Like To Know Where To Set The Camshaft Timing Inside The Heads. I Have A V6 Rlv Motor. I Believe I Have Put The Timing Belt On Right...
Asked by
carltharp
1 ANSWER
3 IMAGES
1994
ISUZU TROOPER
1998 Isuzu Trooper Car
I Need Camshaft Diagrams Mark
Asked by
hugogomez1
1998
ISUZU TROOPER
Flexplate
I Have Broken 2 Flex Plates In A 2 Month Period Could My Torque Converter Be Bad On The Transmission Or What Can Be Causing This Problem
Asked by
qk9
1 ANSWER
2000
ISUZU TROOPER
Engine Wiring Diagrams Please?
I Drove Into A Water Hole And Water Came Into The Floor Boards Ever Since It Has Rained Real Bad. I Replaced The Fuel Pump And The...
Asked by
Hannah L Duer Giffen
14 IMAGES
1994
ISUZU TROOPER
Crankshaft Pulley
6 Cyl Four Wheel Drive Manual 140000 Miles Have To Replace Water Pump, To Do So I Have To Remove Crankshaft Pulley, Center Bolt On...
Asked by
fmoose
1996
ISUZU TROOPER
VIEW MORE
Camshaft Position Sensor Replacement
Engine Noises
Intermittent Misfire
