2000 Isuzu Trooper engine turns over but will not start
60,000 MILES • 6 CYL • 4WD • AUTOMATIC
BRONCS
just replaced the old engine with a reman engine,it started right up and we ran it for a while,no problem with it craking over,it sat for a day and when we went to start it,the engine turned over but would not start
Jun 3, 2010 at 5:45 PM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 3, 2010 at 9:39 PM
