2000 Isuzu Trooper Communication
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHECKPOINT
I cannot establish any communication through the OBD port and my OTC Genisys scanner. Any ideas where to start?
Apr 21, 2009 at 7:17 AM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:206f9f36f7="Checkpoint"]Computer problem
2000 Isuzu Trooper 6 cyl Four Wheel Drive Automatic 140000 miles
I cannot establish any communication through the OBD port and my OTC Genisys scanner. Any ideas where to start?[/quote:206f9f36f7]
Check Fuses and Relays for the EMC/PCM. Also check for a fuse for the DLC. I cannot find a Diagram with the fuse and relay ID's. So check your owners manual and or the underside of the fuse box lid.
Also what problems are you having that you are trying to do a diagnostic?
Apr 21, 2009 at 7:31 AM
CHECKPOINT
CHECK ENGINE LIGHT IS ON AND IT STUMBLES ON ACCELERATION
Apr 22, 2009 at 5:43 AM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:9fb309837a="Checkpoint"]CHECK ENGINE LIGHT IS ON AND IT STUMBLES ON ACCELERATION[/quote:9fb309837a]
Possible causes....
Worn Plugs and Wires - When was your last tune-up?
Coil Pack going Bad.
Vacuum Leaks.
IAC (Idle Air Control) Valve/Motor.
Low Engine Compression.
TPS (Throttle Position Sensor).
Coolant Sensor.
Bad Injector(s)
Bad Injector(s) Harnesses
Have you check the fuses and relays?
Apr 22, 2009 at 4:35 PM
CHECKPOINT
What we need to do is communicate with the vehicle. All fuses appear to be good. What suggestions to you have? Procedure?
Apr 23, 2009 at 4:43 AM
OBXAUTOMEDIC
  • 3,719 POSTS
Ok, Lets check and make sure you have power at the DLC. Check pin #16 it is a Green wire you should have power at all time on theat pin. If not check the #14 (15a) fuse in fuse block behind left kick panel. Also is you Genisis Battery Powered if so are the batteries fairly new? I know some scanner wont read properly with low batteries. Here is the DLC Wiring... I will email it for better reading.
https://images.2carpros.com/forum/automotive_pictures/188069_2000trooperDLCwiring_1.jpg
Apr 24, 2009 at 10:37 AM
