Hello –
Thanks Dieter for the info………still a couple of other questions above I needed answered. Here they are again just in case.
To better assist you is your model the Limited, LS or S model? Also what is your engine size in liter?
Sometimes a cracked ignition coil can cause this or low fuel pressure. It has to be something common to all of the plugs.
For now since the car is running just fine, take it to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. We know it is code P0300 but I just want them to clear all the codes for now. Then just drive it as normal.
There are times the car will throw a code and it can be the computer blinked for a second, the fuel pump maybe dropped slightly in pressure…….a number of things. If the car is running just fine, then I normally make note of the codes and clear them and drive normal. Then if it throws them again now you may have a problem. But if all is okay I wouldn’t worry right now.
Now you do have 95000 on the car so keep the fuel pump in mind for the future. Also, at 75000 your timing belt was to be changed. Please keep that in mind as that could damage the engine if it breaks…….
Keep me posted
Aug 1, 2009 at 5:37 PM
