2000 Isuzu Trooper atf leakage
2000 ISUZU TROOPER
50,000 MILES • 6 CYL • FWD • AUTOMATIC
JOB SUSE BWEUPE
atf leaking,no fill-up plug transmission sealed
Mar 19, 2009 at 1:31 AM
ZACKMAN
  • 4,202 POSTS
Can you see where the leak is coming from? Is it from the front, rear of the engine, driver side, passenger side? Has you gone under the vehicle to properly see where the leak is? Looking at the transmission and its lines is the only way to properly diagnose leaks.
Mar 20, 2009 at 12:23 AM
JSP1014
  • 6 POSTS
there is a check/fill plug located on the transmission pan. there is 2 plugs one will be the drain plug which is the lowest plug on the pan, and the other plug is on the edge and located a little higher than the drain plug, that is your check/fill plug. You should take it to a quick lube shop of some kind and they should be able to fill it for you. *make sure if you decide to remove the check/fill plug you *must* have the vehicle running and in Park or you will get covered in trans fluid and also you will loose a lot of fluid. When its removed a small amount of fluid should come out of this hole that means its full. if no fluid comes out it is low and needs to be filled, just remember to fill it and plug it then drive for a few minutes and recheck it.
Mar 21, 2009 at 11:43 AM
