Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Isuzu
Trooper
Drivetrain
Transmission
Symptoms
Engage
1999 Isuzu Trooper transmission problem
1999 ISUZU TROOPER
105,237 MILES • 6 CYL • 4WD • AUTOMATIC
BAGWASH
MEMBER
1 POST
top gear fails to engage. all other gears work perfectly. no leaks, bangs, crashes from transmission, just stopped working
Feb 21, 2009 at 9:18 PM
KHLOW2008
Experienced Mechanic
Hi bagwash,
Thank you for the donation.
Does the trans shifts into OD and flares or it does not want to upshift from 3rd gear?
Does the CHECK TRANS light shows for 2 or 3 seconds before going off at ignition ON?
Try getting a diagnostic scan done to see if any codes are recorded.
Feb 22, 2009 at 12:22 AM
Add image or video
Ask a new question
Check engine light
Engine won't start
