1999 Isuzu Trooper Transmission
1999 ISUZU TROOPER
100 MILES • 6 CYL • 4WD • AUTOMATIC
XYLVIA
I am replacing the transmission. Should I also replace the transfer case? What consequences of not doing so. What else should I do when replacing the transmission?
Mar 17, 2008 at 4:43 PM
2CARPRO JACK
  • 11,533 POSTS
The t-case should be ok, they are seperated by a seal, and shouldnt share any fluid. I would flush the trans cooler in the radiator at minimum. If the old trans blew up big time, then you may want to consider having the trans cooler replaced or replacing the entire radiator
Mar 19, 2008 at 3:02 AM
