1999 Isuzu Trooper oil pressure
JOHNNY122
Engine problem
1999 Isuzu Trooper Engine Size unknown Four Wheel Drive Manual 114ooo miles
i have 1999 trooper when i start it up there is no oil pressure sometimes it will rise after a short distance i have just had the turbo replaced it was ok untill next day when i started it up and there was no oil pressure again
Jan 12, 2008 at 5:39 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a216df0cfe="johnny122"]Engine problem
i have 1999 trooper when i start it up there is no oil pressure sometimes it will rise after a short distance i have just had the turbo replaced it was ok untill next day when i started it up and there was no oil pressure again[/quote:a216df0cfe]
if you dont have the means to check the oil pressure by using gauge
try to replace the oil pressure switch as a1st step
Jan 12, 2008 at 6:00 AM
