1999 Isuzu Trooper oil change
1999 ISUZU TROOPER
ADSL564
1999 Isuzu Trooper 6 cyl Four Wheel Drive Automatic
I removed a drain plug at the beginning of an oil change and did so without taking time to verify it as the correct drain plug. It was not. I do not know what I drained. It was the only drain plug on the absolute bottom of a drain pan. It was not pink or red, and did not smell like tranny fluid. The fluid was however very thin. The pics in my manual do not mtch what I'm looking @ under the trooper. I was told by O' Reilly auto parts that Chilton nor Haynes MAkes A manual. Any help would be wonderful!
Aug 19, 2008 at 11:54 AM
KHLOW2008
  • 41,814 POSTS
Hi adsl564,
Can you post a pix of the drain plug location here?
Aug 29, 2008 at 2:51 AM
