1998 Isuzu Trooper Hesitation
174,000 MILES • 6 CYL • 4WD • AUTOMATIC
VARUUM
Car starts severe hesitation, spits, sputters after going @ 150-200 highway miles, almost like choking if it had a carburator. Read a little about on line and thought it may be the EGR. Cleaned the EGR and found that it was stuck but seemed to be working properly when i reinstalled but the problem remains. Car starts right back up after a brief stop but the hesitation begins again after only 70-100 miles. Never does this on around town driving, only when the engine has run for extended time. Has new spark plugs but did not replace the 6 ignition modules on top of the plugs. EGR or ignition? Could it be something else ?
Apr 17, 2010 at 6:58 AM
  • 75,988 POSTS
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 17, 2010 at 8:18 AM
