1998 Isuzu Trooper Check Engine Light On
BRAZER
  • 1998 ISUZU TROOPER
  • 6 CYL
  • 4WD
  • 53,000 MILES
I changed the maf senser and the light came on a day later. OBC Code 171 high idle. Should I change the MAP senser too?
Thursday, March 11th, 2010 AT 4:41 PM
MERLIN2021
  • 17,250 POSTS
P0171?
https://www.2carpros.com/forum/automotive_pictures/62217_171_2.jpg
This means either the engine has a vacuum leak, or fuel pump is weak...You may have a vacuum leak, get a can of spray Throttle body cleaner, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs!
Or test the fuel pressure:
Thursday, March 11th, 2010 AT 5:00 PM
