1998 Isuzu Trooper Check Engine Light on
TROOPER2
  • 1998 ISUZU TROOPER
  • 6 CYL
  • 4WD
  • MANUAL
  • 110,000 MILES
The "check engine light" turned on on my 98 trooper. After getting home, I checked and topped all fluids. The "engine light" turned OFF. I took the vehicle for a ride (~1 hr) and the light turned back on. The vehicle is NOT riding or idling rough. What could this be? Could it be a bad sensor or blow fuse?
Thanks!
Monday, February 18th, 2008 AT 5:42 PM
BMRFIXIT
  • 19,053 POSTS
1st check gas cap and make sure its on and tight
and if that didn’t work you need to have it scanned for codes
your local part store or repair shop can help you getting the code s
you can post them back here more help if needed good luck
Monday, February 18th, 2008 AT 8:03 PM
