If the thermostat is stuck closed/shut it will not allow the coolant to flow causing the engine to overheat -could blow the headgasket crack the head and block-seized the engine/etc
Jan 25, 2010 at 11:23 AM
KENYARDA
MEMBER
is the head gasket expensive?
Jan 25, 2010 at 11:46 AM
✓Experienced Mechanic
Its the labor that's gonna hurt Note: labor charges varies with location could range from $70-$130.00 per hr. See below quotes
