1996 Isuzu Trooper 02 sensors
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
THEBRICK65
Engine light was on for some time.Vehicle running very poorly.Pepboys did check engine light pkg.Results:02sensor circuit low.(bank 1,sensor2) Cyl.3 misfire.O2 sensor Heater circuit(bank1,sensor1)02 sensor Heater circuit(bank1,sensor2).They wanted to replace rear right,right front sensors.I changed plugs, air filter,fuel filter and only premium gas.Two plugs were coated in oil.One obviously the 3cyl.The car ran great and light was off for about a week.Now worse.Money is an issue.Do flowchart diagnostic or spend the time and money and replace the sensors?What do you think would be the most cost effective cure to keep her going.She has been a Trooper.Thank You and Take Care.
Mar 21, 2010 at 11:42 AM
  • 75,988 POSTS
Its not gonna do you good replacing the sensors if you're leaking oil into 2 cyiinders this has to be fix before it can purr-Get an engine compression check
Mar 21, 2010 at 11:35 PM
AJ FE
What if you have good compression in that cylinder? Im having the same issue with mine but im getting good compression in cylinder 1 thats missfiring.
Oct 11, 2019 at 2:22 AM
RENEE L
  • 1,260 POSTS
You have posted your question that is over nine years old. I really want you to get an answer. Please post your question as new. For your convenience I am including the link.
Make sure you are logged into the site before clicking on the link.
Thank you for using 2CarPros and have a great rest of your day!
Renee
Admin
Oct 11, 2019 at 11:18 AM
