Just the past 5 days my car was running rough just after starting in movement in 1st & 2nd gear then after a few minutes it was fine. It wasn't drastic but noticable. Then this afternopon when I went to start it it was incredibly rough with no power to drive it. I tried to start it 4 different times then it woudn't start at all. It cranks /turns over fine & the battery is fine. I thought possibley my fuel pump had went since it was theoriginal so I replaced it & the fuel filter. I checked the fuses & relays they are o.k. I'm not sure what else to try. I though about the fuel pressure regulator. Do you have any suggestions to get my car running? I appreciate your help. Thanks
Oct 12, 2010 at 5:41 AM
