1995 Isuzu Trooper water and oil mixed
250,000 MILES • 6 CYL • 4WD • AUTOMATIC
FROGDOGG68
i had no antifreeze fluit in the car just stright water.i drain the radiator to keep it from freezin.and now i have oil and water mixed together.could it b that the frozen ice inside the motor pushed my freeze plugs out.and made water and oil mixed together?
Jan 28, 2008 at 5:50 AM
MASTERTECHTIM
  • 4,750 POSTS
no. if a freeze plug popped it would only leak coolant externally. most likely the crack is inside the engine.
Jan 28, 2008 at 6:20 AM
