1995 Isuzu Trooper trans issues
175 MILES • 6 CYL • 4WD • AUTOMATIC
MARYBEACHFAIRY
I'm wondering if the information offered here is also good for the 95 trooper-mine is a 3.2 dohc. has only reverse and first but can be manually shifted. i read about the winter mode-what about the power mode...is there something i can disconnect to deactivate that. where can i look up what the codes mean? clue-same time this occured-the dash lights went out
Jan 11, 2009 at 1:37 AM
2CARPRO JACK
  • 11,533 POSTS
The TSB is what you are wondering about? you would have to contact the dealer to see if your vin# falls into the vehicle range for theTSB. The other info should be ablr to be applied to yours
Jan 11, 2009 at 7:44 AM
