1995 Isuzu Trooper timing belt
1995 ISUZU TROOPER
TYPACK
Engine Mechanical problem
1995 Isuzu Trooper 6 cyl Four Wheel Drive Automatic
how do you know when belt tensioner is going out
Oct 30, 2009 at 10:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if tensioner is bad then it will no longer be able to hold the belt at the proper tension so the belt will be loose .
Oct 30, 2009 at 12:45 PM
TYPACK
what is the tenscion on the belt mine is loose but how loose or tight should it be
Oct 30, 2009 at 1:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
which belt is this for? A/C, power steering etc..?
Oct 30, 2009 at 2:01 PM
TYPACK
timing belt tension how much play should be in the belt
Oct 30, 2009 at 2:06 PM
