1995 Isuzu Trooper high oil pressure
133,000 MILES • 6 CYL • 4WD • AUTOMATIC
D_PALMERI_DRAFTER
I would like to know what could cause my oil pressure is about 180 psi and never drops below 85 psi. Also I would like to know what is normal oil pressure for this make and model.
May 10, 2008 at 2:53 AM
  • 75,988 POSTS
The oil pump pressure relief valve is not opening- at normal operating temperature should read 57-80psi @ 3K rpm
May 10, 2008 at 6:09 AM
