1994 Isuzu Trooper pedal fade
104,000 MILES • 4 CYL • 2WD • MANUAL
ERROL78
hi, i have brake fade down to half pedal then a reasonable pedal, which only gives poor brake, i have changed the master cylinder 3 times, and bled the master cylinder according to the manual, i have bled the brakes 4 times, the first time useing sequence left rear/ right rear/ left front/ right front, the second time i started in reverse, right front/ left rear/ left front/ right rear, the last times of bleed i dissabled the abs . the abs would appear to be ok, the servo unit appears ok, it goes down when engine is started ok, new pads have been fitted all round, i have checked for any air leaks. i am certain that there is no air left in the pipes, hope you can help as it has beat me , incidentally i have been in the motor trade for over 40yrs on the body side, and only occasionally on the mechanical, based in nottingham uk my car is right hand drive
May 17, 2008 at 7:45 AM
  • 75,988 POSTS
i have changed the master cylinder 3 times, Try opening up the drum and inspect the wheel cylinders for leakage
May 17, 2008 at 7:52 AM
