1994 Isuzu Trooper O2 Sensor
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
ANTHONYTUNDRA
I had the O2 sensor replaced on the above car. However the "Check Engine" light stayed on. I was told that there are 4 O2 sensors or the car and that another one must also be bad. I took the car back to have the problem fixed. The "Check Engine" light came back on after only a few minutes of driving. Are there 4 O2 sensors? If so would they all go bad at the same time? How much should it cost to have one replaced?
May 23, 2008 at 3:11 AM
LEGITIMATE007
  • 5,121 POSTS
mmmmmmmm i'll have to look into tghat I cant picture a car that old with four o2 sensors. but yes all four can go bad
May 23, 2008 at 3:20 AM
MERLIN2021
  • 17,250 POSTS
Read your codes before replacing parts...OBDI 02 sensors were good for about 50,000.
https://images.2carpros.com/forum/automotive_pictures/62217_Codesa_2.jpg
May 23, 2008 at 5:46 AM
