1994 Isuzu Trooper Clutch
1994 ISUZU TROOPER
205,000 MILES • 6 CYL • 4WD • MANUAL
BIGED1064
When I engaged the clutch, the clutch pedal dropped. Is there a lack of fluids? As I understand this vehicle does not have a clutch cable but uses hydraulics.
Oct 16, 2009 at 1:45 PM
AGON164
by dropped do you mean it juststays down because if so its the slave or master cylinder or both. i had the same problem
Apr 1, 2010 at 1:38 PM
